I have been using both the USB port and the MiniProg 3 without any problems programing the CY8_KIT-050 until today. I can acquire the USB port DVKProg5 v1.2 and MiniProg3 v 2.05 but not able to acquire the Target PSoC Device using PSoC Creator 4.2.
I do not have a problem programing the CY8_KIT-042 with the USB port or the MiniProg3. And, not having a problem programing the FreeSoC2 kit (PSoC 5888AXI LP096) from Sparkfun using the the USB port with PSoC Creator 4.2.
At this point my CY8KIT-050 is out of commission. Any suggestions.
Thanks, Mike
PSoC 5 Device Programming
PSoC 5LP
- miniprog 3
It turns out all along I had Vdda = 3.3v and Vddd = 5v and the chip performance is not guaranteed if Vddd > Vdda. I had not had a problem with this setup until today??? When I changed Vddd to 3.3v every thing is back to working fine.
Can you please share a screenshot of PSoC Programmer when you try to program CY8CKIT-050 with MiniProg3.
Please check this KBA which can be useful:
Ankita
