Is there a way to read Vddd and Vdda without using extra analog pins (and voltage divider)?
Running on power boost, and just need to monitor actual system voltages.
HeLi_263931
Level 8
Level 8
100 solutions authored 50 solutions authored 25 solutions authored
Usual solution: measure the internal reference voltage, using Vdda as the reference for the ADC. From the result you can calculate the actual Vdda.
I don't think that you can use Vddd are reference for the ADC, though.
HeLi_263931
Level 8
Level 8
