PSoC™ 5, 3 & 1
How Can i Convert Two individual input pin as BUS? There are two signal Sources and those two need to be converted into BUS form.
Simillarly How can I access individual from a BUS.
Bob_Marlowe
Expert II
Connect both signals together, leaving some room for the signal names
Right click on the first signal and select "Edit Name and Width". Change the name to something that suits your project and select Bus, Left index 1 and for the other signal left index 0.
Alternative: There is a user component that helps you, have a look here.
Bob
Bob_Marlowe
Expert II
Bob
rola_264706
Honored Contributor II
Check out this document on pins .
