ImageCraft compiler and memset function, paging problem
After I switched from HiTech to ImageCraft compiler I found functional errors in the program, which previously worked fine. A closer investigation showed, that a line:
 memset (displayLine, ' ', DISPLAY_SIZE);
had no effect. However if, before the call to memset, I load the MVW_PP register with displayLine's page number, the code works as expected.
Is it a bug in the memset function (caused by overlooking the fact that the new compiler handles paging differently), or should I just change something in the code or settings ?
TIA for help.
I will try to find out more about this and update you.
Ganesh
 Please mention the version of PSoC designer, which you are using for developing the code.
Akshat
