PSoC 5, 3 & 1
Does it uses the ADC_DacTrim()? Any examples how to use it?
ETRO_SSN583
Esteemed Contributor
Going out on a limb, INL is not necessarily a continuous function as depicted in solution
graph. A better method might be to use a power curve fit to an n point test of DAC or even
a least squares fit, the power curve a better approach.
Regards, Dana.
