Hi, I'm working on a project where I tested some aspects of the PSoC5-LP board, but now I need to create a printed circuit on eagle where my system will be implemented. My question is: How can I program the CY8C5888AXL-LP096 without the board? How can i upload the program to the processor?
Thank you for your time,
Carlos
PSoC 5LP
Two choices when programming the chips on the PCB:
Use a MiniProg3.
Get hands on a CY8CKIT-059 Prototyping Kit and use the snap-off programmer.
Both interfaces are the same using GND, Vtarg, scl, sda and XRES. Check the datasheets. MiniProg3 can be used by just plugging it to a 5 posts (2.54mm spacing) interface.
Bob
Hi, thank you for your answer. So, if I use the MiniProg3 I can use the code writen in the PSoC Creator?
Carlos
