Hi Team,
Very good morning,
I am using PSOC5 development board and IR transmit (38k) and receive sensors (38k). Which method to use interface these sensors to PSOC board.
How to transmit at the same time receive same signal. Please any one help on this.
VV
PSoC 5 Device Programming
PSoC 5LP
Can you give me more details about your project and sensor you are using. I have attached link of a project that uses PSoC 4 and IR Sensor below.
Let me know if this helps.
Ekta
Ekta
Thank you for the reply,
We are using transmitter (VSMB294008G ) and receiver (TSOP57436) two modules, How to interface these two to PSOC and How to identify the receiver side when transmitter signals are ON and OFF state.
VV
Hello
The attached project uses a similar receiver you can refer to it to design your project.
Ekta
