I am using cy8cplc20, but unable to configure pin as input.can anyone help me out in configuring the pin as input.The enclosed files are of designer file and code.
Thanks in advance.
shafi
PSoC 1
Just setting the drive mode of the pin to "High Z" changes it to a digital input.
Bob
Bob
Hi Bob,
Firstly thanks for the reply.my another question is that we are using cy8cplc20 microcontroller for powerline line communication between two nodes.so when the two nodes are little nearby the communication is good but when the distance between them is increased,then the two nodes stops communicating.can you help me out with solution for the above.
Thanks in advance.
Shafi
Sorry, I've absolutely no experiences with the powerline components.
Bob
