How to Create Thread in PSOC CY8KIT-059
I want to create a thread in PSOC CY8KIT-059. i  linux we use pthread to create a thread but herei do  not  how to create thread in psoc.
is there any API is available for this ?  please tell me.
waitinf for your reply....
AnkitaS_51
There are ISR for each endpoints inside the file USBUART_episr.c. You can add your code in the OUT EP. When host is sending data to device OUT EP ISR will be triggered.
Bob_Marlowe
Level 10
Level 10
There is no OS in a PSoC, so there is no API fro starting threads. You may consider using free RTOS which could do that.
Bob
One question
How to trigger USBUART Receiving interrupt. i am using USBUART_SOF_ISR. do i need to call it in main function as video tutorial has given on website for interrupt for switch ?
Hey Bob i am waiting for reply
Bob_Marlowe
Level 10
Level 10
May I have lunch?
I cannot find an interrupt. Probably you need to poll for USBUART_DataIsReady()
Bob
Sorry i did not know that.
Hi Bob,
USBUART working with polling method but what i want,  when ever any data is coming through USBUART (Interrupt like switch)i want to perform some action.
So this thing i am looking  for ?
one more thing how to use USBUART_SOF_ISR ?
Bob_Marlowe
Level 10
Level 10
SOF is "Start Of Frame" I do not know when it exactly fires.
Bob
Hi  Bob,
Since i stucked on that part only  i did not find enough document related to USBUART ISR and how to use it . so can you do a favor, in your team can you ask about that because it is really important to me tomorrow i have to delivered the code but i am stuck with USBUART ISR.
Please  help me waiting for your ans...
Bob_Marlowe
Level 10
Level 10
I would suggest you to get in contact with Cypress directly: At top of this page select "Design support -> Create a Support Case" and ask your question. You will be helped by a Cypress engineer.
Bob
odissey1
Level 9
Level 9
vinay,
check this thread if any relevalt information re: USBUART and ISR
http://www.cypress.com/forum/psoc-5-device-programming/looking-advice-using-usbuart-interrupt-driven...
Hi ,
Is it possible to know how to enable USBUART ISR because it is different from  normal isr
waiting for your reply
AnkitaS_51
