PSoC 5, 3 & 1
Hi All,
I am looking for a way through which I can shift my signal by 90 degrees. I want to avoid using flip flops.
Looking forward to your suggestions.
Awais
odissey1
Honored Contributor II
maknight,
you can use PLL to get 90 deg shift
http://www.edn.com/design/analog/4411037/Demystifying-the-PLL
Bob_Marlowe
Expert II
"shift my signal by 90 degrees" So, what is your signal? Where does it come from. I just assume it is a digital signal, is it?
And what is the reason you do not want to use a FF.
Bob
Thank you, Bob, for your reply!
Correct, It's a digital square wave signal coming out of the comparator and entering into the LO input of the Mixer.
I am avoiding using flip flop because, in my full schematic design, I get half of the frequency at the output of the flip-flop.
I was thinking about shift register but I am not sure how should I use it. Maybe a shift register with the not gate? What do you think could be the best thing i can do about it?
Looking for your reply!
Awais
Bob_Marlowe
Expert II
Frequency range?
Bob
It's about 100 KHz
Bob_Marlowe
Expert II
You could try to measure signal high and low time (or frequency and duty cycle) and generate a 90 degrees shifted signal using a PWM.
Bob
This could be possible but I would not be flexible if my input frequency would change for some reason.
Bob_Marlowe
Expert II
I thought for a constantly measure of a single cycle input signal and controlling the PWM. Can probably done with a 100kHz signal. What are the precision restrictions you have got? And: What is the lowest frequency to handle?
Bob
I can maximally go town to 90KHz.
Bob_Marlowe
Expert II
Quite tough, give it a try...
Bob
odissey1
maknight,
