PSoC 5, 3 & 1
I am facing the following problem:
I want to create  boot loader and bootloadable project. But i am not seeing the advance settings in creator 3.2. How i can do this?
I attached the pic for better understanding of my problem.
Looking forward for your replies.
Awais
ETRO_SSN583
Esteemed Contributor
These should help -
http://www.cypress.com/documentation/application-notes/an73854-psoc-3-psoc-4-and-psoc-5lp-introducti...      AN73503 PSoC® 3, PSoC 4, and PSoC 5LP Introduction To Bootloaders
http://www.cypress.com/documentation/application-notes/an68272-psoc-3-psoc-4-and-psoc-5lp-uart-bootl...                       AN68272 UART BL     PSOC 3, 4, 5LP
http://www.cypress.com/documentation/application-notes/an60317-psoc-3-and-psoc-5lp-i2c-bootloader                                         AN60317 I2C BL         PSOC 3, 5LP
http://www.cypress.com/documentation/application-notes/an73503-usb-hid-bootloader-psoc-3-and-psoc-5l...                               AN73503 USB HID BL with GUI Host     PSOC 3, 5LP
http://www.cypress.com/documentation/application-notes/an86526-psoc-4-i2c-bootloader        AN86526 - PSoC® 4  I2C Bootloader
http://www.cypress.com/documentation/application-notes/an68272-psoc-3-psoc-4-and-psoc-5lp-uart-bootl...                                       AN68272 - PSoC® 3, PSoC 4 and PSoC 5LP UART Bootloader
http://www.cypress.com/forum/psoc-3-known-problems-and-solutions/multi-application-bootloader
Regards, Dana.
Thankyou Dana for your reply,
All the links shows me the right way but the problem is with the creator. I have creator 3.2. When i create a new project and want to select "Application Type " in advance settings. It is not visible in creator 3.2. This is what i also showed in my attachment.
Looking forward for your suggestion.
Awais
ETRO_SSN583
From 3.1 release notes -
Note Beginning with PSoC Creator 3.2, the “Application Type” option is removed from the New Project dialog box. PSoC
Creator automatically recognizes the application type from the TopDesign schematic. However, this update does not affect the
existing bootloader projects.
Basically placing the bootloadable or bootloader component on top schematic invokes
the design.
Regards, Dana.
Oh Ok.
Thankyou once again for solving my problem 🙂
Awais
ETRO_SSN583
Glad to have assisted.
Regards, Dana.
