Hi - I'm having trouble getting a temp sensor AMUX to route.
PaCo_972561
5 questions asked 5 replies posted Welcome!
It complains failed to route net "AmuxNose:AMux_1_CYAMUXSIDE_A".  I disabled all other components and it still can't route the AMUX.  It's now essentially the same as the example thermistor calculator code example.
Also: Is there a way to create a support case?
thanks - Paul
Vasanth
Hello Paul,
Cypress Developer Community is our primary platform for support now. Could you please let me know the exact part number you are using ? Also let me know the modifications you have done to the example code ? Have you changed any pins in the design and locked them to some other ?
Vasanth
