02:53 AM
Aug 14, 2013
02:53 AM
Hi all,
While programming CYRF69103 using Miniprog3 Rev*A, i'm getting the following error!!
Programming Terminated
Detected SiliconID: "00 00 00 00" is not in database
Kirangkr
Labels
PSoC 3
03:06 AM
Aug 14, 2013
03:06 AM
I had the very same error a few weeks ago. File a technical MyCase and they will help you. The cause (with me) were some leftovers in the registry from former Creator installations which I could not remove (even not manually)
Bob
permanently having a very small reply window, no helps??
Bob
Aug 14, 2013
03:06 AM
Aug 14, 2013
03:06 AM
Bob
Bob
03:13 AM
Aug 14, 2013
03:13 AM
Hi Bob,
Thank you for your reply, could you be more specific!!
Kirangkr
Aug 14, 2013
11:10 AM
Aug 14, 2013
11:10 AM
I said: File a technical MyCase.
At top of this page go to "Support & Community->Technical Support->Create a MyCase"
Bob
Bob
Aug 14, 2013
11:42 AM
Aug 14, 2013
11:42 AM
12:36 PM
Aug 14, 2013
12:36 PM
I got that message several times before. it happened to me when the programmer was not properly acquiring the device. Often I just have to unplug the programmer and/or reboot my computer other times I have to check device connections (if not using a cypress kit check power and SWD signals )
10:50 PM
Aug 14, 2013
10:50 PM
Hi All,
Thank you so much for all your reply.
Kirangkr
