PSoC 5, 3 & 1
alma_284856
New Contributor II
 Hi everyone,
I use a L6234 three phase driver motor with my PSOC. To control my motor I need to get 3 PWM which are dephased 120° as you can see on the picture attached.
What is the best solution?
Thank you
Alexis
ETRO_SSN583
Esteemed Contributor
This might help -
http://m.eetindia.co.in/STATIC/PDF/200910/EEIOL_2009OCT29_SIG_AN_01.pdf?SOURCES=DOWNLOAD
Regards, Dana.
