PSoC™ 5, 3 & 1
JaRa_1183061
New Contributor II
I am using existing libraries and I am getting this error Plus.h (in my main file) No such file or directory exist.  Then I moved the main file to the same folder as Plus.h file, then the issue goes to the project.h file.
How do I ensure that all files have access to each other.
Alakananda_BG
Can you please let us know which IDE you are using?
If you are using PSoC Creator, you should include the directories in Build settings--> Compiler--> Include additional libraries. There you need to give the path name of where the plus.h exists.
Alakananda
Alakananda_BG
Alakananda
