PSoC 5, 3 & 1
I tried to bulid the uvc_example on my FX3 board ,however ,filed. But when I changed another example(basic example) ,it can be done.I don't know why.If there any position should be configured?
What do you mean by failed? Do you mean you are not able to see the device on device manager? Please note that uvc example does not come up in the control center unlike basic examples and you can see at under "Imaging devices" section in the device manager.
If you are not able to see it under the Imaging section, please create a Tech Support case.
-Madhu Sudhan
