PSoC 5, 3 & 1
I am trying to establish between the cypress board and the TI toolkit. I am fairly new to the I2C communication. Could the community please direct me to the appropriate tutorials?
Bob_Marlowe
Expert II
Byte I2C interface is quite simple: After setting up the component and starting it you use
    I2C_MasterSendStart(DeviceAddress,I2C_WRITE_XFER_MODE);    // Initialize a transaction for writing
    I2C_MasterWriteByte(Register);                // Indicate which register you want to write to
    I2C_MasterWriteByte(Value);                // Write to register
    I2C_MasterSendStop();                    // End of transaction
When you want to read from a device you use (example for reading two bytes
    I2C_MasterWrite(Register);                // Indicate which register you want to write to
    I2C_MasterSendRestart(DeviceAddress,I2C_READ_XFER_MODE);
    I2C_MasterReadByte(I2C_ACK_DATA);            // Read from register
    I2C_MasterReadByte(I2C_NAK_DATA);            // Read from register, last byte is NAKed
Not too difficult. Keep in mind that most of the APIs (except those for reading a byte) return a status byte which, when non-zero indicate an error condition.
The high-level APIs must be used in this way:
Writing to slave Count bytes
I2C_MasterWriteBuf(SlaveAddress,DataPtr,Count,I2C_MODE_COMPLETE_XFER);
Reading from Slave sending register/command byte first:
I2C_MasterWriteBuf(SlaveAddress,&RegAddress,1,I2C_MODE_NO_STOP);
I2C_MasterReadBuf(SlaveAddress,DataPtr,Count,I2C_MODE_REPEAT_START);
Bob
Bob_Marlowe
Expert II
Bob
