IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
PSoC 5, 3 & 1
ScEn_283436
New Contributor II
Can someone point me to the data sheet that shows you how to read the die temperature in a PSoC 3?
Nick
        As you know, Start DieTemp module and "DieTemp_GetTemp(int16 * temperature)" You can get "the temperature in degree of Celsius"... Anything else? [ http://www.cypress.com/?rID=46454 ]
        IC, I see. I couldn't get the die temperature yet still actually. "DieTemp_GetTemp( &temp )" had never success. "DieTemp_Query( &temp )" get return CYRET_TIMEOUT always. You have to rise MyCase and let us know.
Man! Wait, wait.
This code is working!
Needs Start and Stop everytimes.
//  unsigned char sp;  int temp;
       while(1)
       {      BLed_ON;
              while( DieTemp_Start()!=CYRET_STARTED ) {};
              BLed_OFF;
              sp= DieTemp_Query( &temp );
              if( sp==CYRET_SUCCESS )
              {   LCD_Printf(0,0, " Die Temp=%d ", temp );
              DieTemp_Stop();
              if((++k%10)<5) BLed_ON; else BLed_OFF;
              CyDelay(10);
