PSoC 5, 3 & 1
doso_1282421
New Contributor
I am planning to use PSOC 4 or 5LP in my new design board to read one-wire IP protection devices DS28E15.
I have a project that can run and compile on MK60X256VLL100 device and I want to convert it to a PSOC project.
I know that it is possible but I don't know how to do it.
I attached the NXP project, and I will be happy to have some ideas
LinglingG_46
Your question is in a big range, I am so sorry for don't give some positive help to port the code from NXP to PSoC.
LinglingG_46
Does the attached project are developed by yourself?
Although I don't know about the NXP chip, I think the control logic is the same.
It is a one-wire control mode, I think the most important thing is the timing.
doso_1282421
New Contributor
The attached project is a combination of a driver that was developed by MaximIntegrated (One-wire, DS28E15, Sha256) and a user commands uart that was developed by a subcontractor few years ago.
LinglingG_46
LuMo_1653921
New Contributor
did you success converting to PSoC4? if so, can you share your code?
Thank you!!
