06:56 PM
Mar 18, 2011
06:56 PM
How do I adjust the contrast ratio for my LCD screen with my dev kit?
Jeff
Labels
PSoC 5LP
02:47 AM
Mar 19, 2011
02:47 AM
Hi Jeff,
In the board that has been shipped, the LCD contrast is set by the resistir divider, R69 and R68. This can be seen in the board schematic . To set the contrast manually,
- R69 and R68 has to be removed
- R67 has to be soldered. R67 should be a potentiometer of value 10k.
- Adjusting R67, sets the contrast.
-Udayan
02:44 AM
Mar 20, 2011
02:44 AM
Jeff,
If you are using CY8CKIT-001 Developement kit, then the potentiometer R31 is used for LCD Contrast Adjust.
dasg
