There are "Interrupt type" configurations in both Pin and Interrupt components. If I connect a Interrupt component to the Pin IRQ, which interrupt takes effect? For example, Pin interrupt type is set to be Falling edge and Interrupt component interrupt type is set to Rising edge, is the interrupt triggered by rising edge or falling edge?
Winston
PSoC 5LP
tags,
Preferred interrupt setting is DERIVED, which guaranties that Pin isr setting will take effect. It doesn't matter whether Pin isr set to the rising or falling edges, the actual signal on the Pin isr wire will go High on interrupt.
/odissey1
tags,
/odissey1
