I'm trying to use the CY8CKIT-059 (containing a psoc5lp) to create a low power capsense button. The button works fine, but the addition of the capsense module adds about 900uA to the sleep mode current, which is pretty significantly beyond what I was expecting. If I disable the capsense module in the schematic editor (and comment out the code), my sleep current goes back to about 2uA. If I just enable the capsense module but never run any code (no CapSense_Start(), etc) it still adds the 900uA current.
Am I doing something wrong here? My code is below, and the project is attached.
#include "project.h"
CY_ISR(WakeupIsr)
SleepTimer_GetStatus();
CyGlobalIntEnable; /* Enable global interrupts. */
//CapSense_1_TunerStart();
/* Place your initialization/startup code here (e.g. MyInst_Start()) */
isr_StartEx(WakeupIsr);
SleepTimer_Start();
CapSense_1_Start();
CapSense_1_IdacCH0_SetValue(255);
CapSense_1_InitializeAllBaselines();
for(;;)
/* Place your application code here. */
if(0u == CapSense_1_IsBusy())
CapSense_1_UpdateEnabledBaselines();
CapSense_1_ScanEnabledWidgets();
if (CapSense_1_CheckIsWidgetActive(CapSense_1_SENSOR_BUTTON0__BTN)) LEDPin_Write(1);
else LEDPin_Write(0);
//CapSense_1_TunerComm();
CapSense_1_Sleep();
CyPmSaveClocks();
CyPmSleep(PM_SLEEP_TIME_NONE, PM_SLEEP_SRC_CTW);
// sleeping here
CyPmRestoreClocks();
CapSense_1_Wakeup();
//CyDelay(1000);
/* [] END OF FILE */
Jeremy
PSoC 5LP
The behavior is expected because When you put the CapSense component inside the schematic and build the project, the analog components will be connected internally and draws some current. Please use the system level API "SetAnalogRoutingPumps()" and disable the analog pumps. You can observe some significant reduce in the current. Please refer page number 30 in the PSoC 5 system reference guide for more information of this API attached with this response.
Thanks and regards
Ganesh
Thanks and regards
Ganesh
