I need develop application that low negatives voltages in pins of my PSoC, Can I do?
PSoC 5LP
Please check links and answers in this thread - many solutions available.
Thanks. I read the information. I must do a aconditionation of signal, but I don't handle negative voltajes.
sciens,
PSoC can tolerate negative voltages as low as -0.7V on its pins, voltages below will be clipped by the protection diodes. To assist you better, please provide more information on your project.
/odissey1
Hello!
Thanks for the information. Then, I make a encephalogram of 32 channels. I would like capture signals through AMux, and then use ADC DeltaSig, then use VDAC to pass a other pins out for use INA or AD620...
