PSoC 5, 3 & 1
Our group has purchased the evaluation board for the chip CYP15G0101DXB and we are unable to use the optical module.  The information that came along with the eval board never explains how to use the optical module and we have tried several different setting combinations to make it work.  Any insight would be benificial.
Please check the KB Article: "       Using the optical module interface on the HOTLink II eval boards       "
This should answers your question. If you are still unable to proceed, feel free to update this post.
