CY8CKIT-050 PSOC5 5LP development Kit not detected on windows 10
seku_495601
5 replies posted 5 sign-ins First solution authored
      my kit CY8CKIT-050 PSOC5 5LP development Kit not detected on windows 10
PSOC Creater 4.4  not detected the Kit
my hardwar Manager show  DVKProg5(unconfigured)
How can i resolve it.
seku_495601
Start Working .iam install Driver in Windows Non Digital Signature Mode then Start Working  thanks
Raj_C
250 solutions authored 500 replies posted 50 likes received
Hi @seku_495601,
For this issue, there can be multiple reasons. You can follow the given steps and let us know if it works.
1) Can you check the Device Manager for the drivers as shown in the screenshot.c2a4aa43-3786-466d-bfd0-40c6c9b7609c.PNG
Verify the path for the DVKProg5. If it is not showing like this then share your screenshot for the same.
2) If the problem still persists follow this Community Thread
3) You can also share screenshot of the PSoC creator's 'Select Debug Traget' panel.
4) Check if the Green Power LED is ON when the USB cable is connected to the programming port.
5) Have you tried this device before and successfully programmed it or is it for the first time that you are using this device.
Raj Chaudhari
seku_495601
