Can i make actve_high setting in LED while placement instead of following code in main.c.  //Set port drive modes for LEDs
  PRT0DM0 |= 0b00100010;  //strong on P0[5],P0[1]
  PRT0DM1 &=~0b00100010;
  PRT1DM0 |= 0b10100100;  //strong on P1[2]
  PRT1DM1 &=~0b10100100;
PRT2DM0 |= 0b10100000;  //strong on P2[5],P2[7]
  PRT2DM1 &=~0b10100000;
 Yes, You can always set the drive modes and initial value in the pin settings. The firware register settings allow you to set and change at run time.
Thank You. It works.
ETRO_SSN583
Level 9
Level 9
You can alwyas use the LED module as a simple way of controlling LED.
Has advantage that if mixed I/O in port it instantiates shadow registers
to avoid R modify W problems.
Regards, Dana.
Thanks Dana.
