PSoC™ 5, 3 & 1
 I was looking for building a board for PSoC3, the boards  Cypress provides are high end boards not afforable for students.
What is the starting point i should look for building the board. Any documents will be helpful
@akash u can try open source board for PSoC
contact @kmmankad he designed PSoC board at low cost
ETRO_SSN583
Esteemed Contributor
Try these -
http://dangerousprototypes.com/forum/viewtopic.php?f=56&t=2823
     http://moeller.io/psocmini.html
Regards, Dana.
At my University we use a homebuilt PSOC3 beakout board and EZ-USB based programmer. kmmankad, has done a good job at dessigning a basic board, you might want to use this schematics as starting point to design your own layout.
 http://kmmankad.blogspot.com/
You also find disscussion about kmmankad's board and programmer on dangerousprotorypes.com forums
 a good appnote on basic PSOC connnections can be found on http://www.cypress.com/?docID=36144
