Hello everyone,
I am wondering what is the best approach to program a PSoC5 without miniprog. I found different way to do it but I have several basic questions to choose the one which fit with my needs:
-Using a bootloader USB-UART
It means programming it once via a miniprog to put the bootloader, but can I use the same port USB to send data via USB-UART? There is no debug right?
-Using cy7c68013A
I found the schematic in attachment. How does the cy7c68013A convert the USB to SWD? The I2C EEPROM is only to store the VID/PID of the USB? There is also no debug?
-Using an other PSoC5 as the Freesoc 2
Do you have an idea of what is inside the second PSoC? A boatloader obviously, but how it allows to program and debug the other PSoC?
Thank you very much
PSoC 5LP
Get a CY8CKIT-043 or -059. It has got a snap-off programmer which you can use for programming most PSoCs.#
I am using this C language book, but you may start with the original by Kernighan and Ritchie.
Bob
Bob
Hello Bob,
Thank you for the answer, but my goal is not to buy anything but understand what is in the CY8C5868LTI-LP039 to use it as Kitprog on-board Programmer / Debugger.
Thank you
The magic word is ISSP (in-system serial programming protocol). Type this term into the "Enter Keyword" field at top of this page and you will get some stuff to read that lasts for this weekend 😉
Bob
