Bebuild - does it change my hex file
Does rebuld/ clead and build change my hex file....
and also Using different creatos with all the same version of components provide with different hex files???/
Bob_Marlowe
Level 10
Level 10
I am not sure about if for instance date and time of compilation is included into a hex-file since there are comments allowed.
Rebuilding a project may of course lead to different outputs since there are often no regulations of the order of placements optimization stages and similar things. Especially because there are optimization methods using monte-carlo-algorithms which -as the name says- are using random numbers.
Bob
