BSDL file for CY8C3866FNI-210/72WLCSP
LeKu_697901
I'm lookinfg for a BSDL file for CY8C3866FNI-210/72WLCSP.
Where can I download it?
Rakshith
Hi leku_697901,
Can you confirm that you have installed PSoC Programmer and not Cypress Programmer?
Either way, I have attached the PSoC3 folder for your reference.
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi leku_697901​,
Please refer to this KBA for more information regarding the BSDL files - PSoC® 3, PSoC 4 and PSoC 5 BSDL Files - KBA84780
You can find the BSDL files in this location in your PC if PSoC Programmer is installed in the default directory - C:\Program Files (x86)\Cypress\Programmer\3rd_Party_Configuration_Files\BSDL\PSoC3
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
I installed the PSoC programmer and there is no the 3rd_Party_Configuration_Files folder in the c:\Program Files (x86)\Cypress\Cypress Programmer\
Rakshith
Hi leku_697901,
The directory you mentioned is - 'c:\Program Files (x86)\Cypress\Cypress Programmer\'
Can you let me know if you can find the files in this directory - C:\Program Files (x86)\Cypress\Programmer\3rd_Party_Configuration_Files\BSDL\PSoC3
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
No, there is only ​Cypress Programmer ​folder under ​c:\Program Files (x86)\Cypress\
Rakshith
Hi leku_697901,
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Ok. You're right.
I installed CyProgrammer_2.1.0.226.exe
Thanks for your support.
