01:06 AM
Feb 22, 2013
01:06 AM
Want a PSoC Designer project / board reference for Brushless DC (BLDC) motor control using PSoC 1? See -
Labels
PSoC 1
Feb 22, 2013
07:04 AM
Feb 22, 2013
07:04 AM
That is a rather interesting application! Although the additional board needed is no longer availlable the used procedures stay the same. Thank you for digging this out!
Bob
Feb 22, 2013
08:58 AM
Feb 22, 2013
08:58 AM
As you can see the example project is 2008, very current.
Regards, Dana.
Feb 26, 2013
05:16 AM
Feb 26, 2013
05:16 AM
Dana,
The example project was last updated in 2010. However using it in newer versions of PSoC Designer should not break the functionality. If it all it does, we are here to fix it!
Arvind
Feb 26, 2013
06:17 AM
Feb 26, 2013
06:17 AM
Arvi, certainly seems if its being advertised as a solution Cypress should
check it out in 5.3 ? At ther very least see if it rioutes, compiles. Just sayin.....
Regards, Dana.
