PSoC 5, 3 & 1
I've compiled the UART_Rx.cywrk example in the CY8CKIT-001 development kit and have been unable to get it working while sending characters over RS232 using Labview. I've send "LCD". It shown  double alpla and japan character. Even I use hyperterminal also same.  Any ideas what might be causing the problem??  Thanks.
Are the baud rates equal?
Do you have receiver echo to the transmitter?
 This could possibly be due to Baudrate mismatch as highlighted in the post earlier. Please ensure that the baud set on the labview module matches with the baud set in the PSoC project.
