IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
PSoC 5, 3 & 1
Hi Team, i tried converting AN78175_Samples from an earlier version to PSoC Creator 4 version,  and Creator 4.0 came up with an error, "cannot open linker script file micro-names.inc , no such file or directory.
Would you please update and fix this project at your earliest convenience,
kind regards,
Johnspark
AnkitaS_51
This issue will be resolved if you do remove the Custom Linker Script by going to Project>Build Settings as shown in image attached.But that ld file is needed for AN.
