PSoC 4
when I inset mini prog into my design board. The psoc creator can not know the chip. my chip is cyble10563-56.
Bob_Marlowe
Expert II
You should update the miniprog3 firmware to latest revision.
Bob
can you give me a new version link of mini prog 3?
what version is the lastet revision?
Bob_Marlowe
Expert II
Connect MiniProg3 to your PC, start Cypress Programmer 3.24, select MiniProg3, go to Utilities and check for updates.
Bob
it failed. it said  '                                                               | FAILED! FW Version is up-to-date. No need of Upgrade. Hex: 2.05 MiniProg3: 2.05
Bob_Marlowe
Expert II
So the problem might be
The MiniProg3
Your board.
Can you
  • Check by connecting your MiniProg3 to a Cypress Kit (a -049 would be ok) to see if it is working
  • Post schematic of your board, so that we can check for correctness
Bob
it is my schematic.It worked when I only provided power by mini prog
but it dose not work when I provided power by my board.
