MaHo_4757026
25 replies posted 10 replies posted 5 replies posted
At my board I'm using CY8C4014SXI-420. Since I'm using "emulated eeprom" I receive an error on verifing flash after flasing:
"There was an error while programming the device: PSoC Programmer reported error (100 - FAILED! Unknown SROM status code)"
I'm able to erase, and flash other applications succesfull, but for some reason the use of Emulated EEPROM is giving me issues. The application itself works ok, including the use of the emulated EEPROM. I used: https://www.cypress.com/documentation/code-examples/ce195313-psoc-emulated-eeprom as a reference.
1. What can be wrong?
2. How can I check the stored/changed EEPROM data in the application? I can read the hex to log in "PSoC programmer", but what row will be changed?
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
>>Can you please share the project with which you are facing the error
>>If you configure the EEPROM at fixed memory address then you can read that address in the debugging window else if you do not fix the eeprom address then it would be difficult to find the location where the EEPROM values are stored.
Alakananda
Alakananda
MaHo_4757026
Seems it's an checksum error while verifying? Is the emulated eeprom data in flash also used in checksum calc that can cause the error? How to solve this?
MaHo_4757026
Cypress support? Can you help here? Do you need to have more info, just let me know. The issue is not resolved yet.
Alakananda_BG
Alakananda
Alakananda
Attached the project
