Hey dear specialists,
my project is defined as follow:
requirements:
1) Measure brushless rotor (north south pole´s gauss) and showing +-value on LCD
2) would be fine that LCD can offset to zero at the beginning
3) platinum version --storage max values.....
technical details
Hall sensor ist feeded with 5V and deliver about 2,3V if there is no influens with magnetic field.
with 1600 gauss magnet there is a range of 0.5V to 4.1V.
the sensor give 1,3mVolt per gauss
what happen until now
set LCD to zero is working with potentiometer, but if value goes under zero LCD show a positive value 65535 of a 16 bit code.
My question so far:
1) is there a nice hardware solution to fulfill my requirements, hence im too stupid for this
SAR decription on page 8 shows a lot of "single ended result formats", which I´m not able to match in my tons of versions on this project
2) software solution
- meaning-
read start value of Hall sensor -storage it in a register or variable then subtract it from the measurement-
very best regards and thanks in advance
Harry
sorry my electronics are 30 years ago and i never played with micro controller, but i HAVE FUN with this small things, which are smarter than ME
PSoC 4 Architecture
You can get both versions to work correctly:
The issue is the LCD_PrintNumber() API which only prints unsigned ints. You will nwwd to write the polarity first (+,space or -) when negative change the sign and then use LCD_PrintNumber() with the adjusted value.
Happy coding
Bob
PS: Where in Germany are you located? I live near Bremen.
Happy coding
Bob
thanks Bob I guess it but I wasnt sure because I am a big NOOB
i have to frustrate you, because I am from VIENNA
is there a community in Germany?
SERVUS
Harry
No frustration at all. Wien is such a beautiful town, I love it!
Bob
