AsD_4717706
             I am trying to program the CY8C4025AZI-S413 using the PSoC programmer version 3.26.0.2791. The target device is getting detected but not able to program the hex file. The target device is coded with different PC and generated the HEX file and send over an email and then it was tried to program using PSoC program.
error log of programmer--
Successfully Connected to KitProg/080A17C7031C3400 at 3.45.51 PM | KitProg Version 2.18
Opening Port at 3.45.51 PM                                      |
Program Finished at 3.45.48 PM                                  |
        | FAILED! Can not acquire device in SWD mode!
Please, check the following items:
        |  - the connection between the programmer and the PSoC;
        |  - the correct programming protocol is selected;
        |  - the correct connector option is selected.
Program Requested at 3.45.48 PM                                  |
VenkataD_41
The CY8CKIT-042-BLE base board contains the kitprog1 which can program all PSoC 4/5 families.
1. Please go through the following PSoC 4 programming troubleshooting guide. You may find the issue.
Troubleshooting PSoC® 3/4/5LP Programming/Debugging Issues - KBA210619
If still you are facing any issues after going through the above document,
2. Please attach the images of your programming set-up.
3. Please attach the schematics of your CY8C4025AZI-S413 board.
4. Please attach the screenimage of the PSoC programmer so that we can see PSoC Programmer settings you are using.
Ganesh
VenkataD_41
Ganesh
VenkataD_41
The latest PSoC Programmer version is 3.28.7 . Please install that too from the below link.
https://www.cypress.com/documentation/software-and-drivers/psoc-programmer-archive
Ganesh
