PSoC 4
user_3568726
New Contributor II
I download CapSense  code example, i compile the project , but  can not open the ELF file  using uc/probe, it shows error as picture below, how to solve this problem? thanks.
LinglingG_46
Does you do the process depending on CY8CKIT-040 kit guide?
You can download the kit setup and install it, find the PSoC4000 Pioneer Kit Guide,  following the steps to use the uc/probe.
LinglingG_46
