Dear Receiver,
Could you please check the attached file ?!
They're all default example codes in my PSoC Creator 4.4.
Why only "5 example codes here ?! I'm certainly sure that so many example codes here before.
I don't know what happen with my PSoC Creator 4.4. Could you please help me to check my confusion ?!
Thank you so much.
PSoC 4 MCU
Hi @Tim_Shih,
This issue was due to PSoC Creator Update Server cannot be accessed.
Now it's solved.
Thank you for your patience.
Warm Regards,
Gautami J
Hi @Tim_Shih ,
We have forwarded your query to our internal team, who will evaluate your query.
We will provide a response as soon as we get an update from our internal team.
Thanks and Regards,
Gautami J
Cypress Semiconductor Corporation
An Infineon Technologies Company
But I'm sure the internet is ok and my account is also ok!
Thank you so much.
The same issues are also in my PSoC creator.
Hi ~ Jiabin,
Do you solve this issue?!
Thank you!
Hi @Tim_Shih ,
I directly went to the github repository of Infineon, downloading the project.
https://github.com/orgs/Infineon/repositories?language=&q=psoc-4&sort=&type=all
ya~ but many useful examples or components you can't get all of them in the github.
For example: PSoC Creator "off -chip" component.
Thank you so much.
It does the same thing with PSoC Creator 4.2 when not connected to the Internet. So a stand-alone PC is out of luck it seems.
We have created a ticket for this with the internal team.
The team is working on the issue and it will be fixed shortly.
Thanks for your patience.
Warm Regards,
Gautami J
This issue has been fixed.
Hi @Tim_Shih,
Now it's solved.
Warm Regards,
Gautami J
