Are there any registers that can be used to transfer data from before a watchdog reset to after?
I have tested bob's advice, and verify it make sense after wdt reset.
#define __no_init __attribute__((section(".noinit")))
uint32 mydata[2]__no_init ={1,3};
The IC will not clear the RAM, but it need to re-initialize the ram after the reset.
Every register will initialize after a watchdog reset.
Or you can describe what do you want to do.
If someone has another opinion, welcome to discuss.
One way will be to save data in internal flash or external flash/ram.
There is a compiler directive (not much time to investigate). Try
#define __no_init __attribute__ ((section (".noinit")))
and later:
uint32 MyData[50] __no_init;
Problem might be to check whether data is valid (after a power-down)
Bob
