I'm getting error "Warning-1350: Asynchronous path(s) exist from "Clock_1" to "\Timer_1:cy_m0s8_tcpwm_1\/tr_overflow"".
I have reduced components for this problem to the following design
If I exchange the NOT component with Sync component, there is no error any more. But datasheet remarks:
s_in – Input
Signal to be resynchronized. The signal must have a pulse width of at least one clock period plus 2 ns.
I think, ov will only be high for one cycle of Clock_1. So, is this solution ok or is there any other solution ?
Regards Rolf
PSoC 4 Architecture
Hello Rolf,
Using a SYNC component instead of NOT should work fine.
You can refer to the document 'Digital Design Best Practices' , page 24: https://www.cypress.com/file/179061/download .
In figure 34, the input to the sync component is 'tc' which is also high for one clock cycle.
Best Regards
Ekta
r.s.jahn,
Options:
(1) Set input pin DCC_unfiltered input to "Syncronized".
(2) Leave Sync in place of NOT, but use BUS_CLK clock (MASTER_CLK on PSoc4?)
Hello Rolf,
Best Regards
Ekta
Funciona muy bien. Elimino el "warning". Muchas gracias!
