PSoC™ 4
HI,
I want to give clock pulse in to a output pin,after a count remove that clock.I am attaching my code with this,but this is not working
module component01 (
output reg step,
input   clk,
input   clock
parameter count_value = 10;
//reg [count_value:0]count ;
reg [count_value:0] temp_count ;
    always @ (posedge clock)
    begin
        step <= clk;
if(temp_count < count_value)
        temp_count <=  temp_count +1;
    //else
    if(temp_count==count_value)
     step <= 1'b0;
    end
    end
endmodule
JobinT_31
Can you please attach the project, so we can try to analyse and debug the issue. I have concerns over the bland line between " if(temp_count==count_value)" and "step <= 1'b0;"
Jobin GT
