I'm trying to implement USB on my PSOC4 CY8C4247AZI-L475 device. The board is powered from USB through a 3.3V regulator. And the USB data lines are directly connected to the PSOC4. I'm loading the example project USBFS_HID01 and change the processor to the one i'm using. But when i program the device the USB is not working. Device manager doesn't detect a new device. Is there something I have to set up additionaly or could it be related to windows drivers.
Kind regards,
Corné@@
PSoC 4 Architecture
We assume that you are using custom board and not PSoC Development kit. Did you take care of the VBUS pin? The USB PHY is powered by the VBUS power pad of the PSoC device. The VBUS pad can be driven either by the host VBUS (bus-powered) or by external supply (self-powered).
Hima
At the beginning of the main() function of the example project USBFS_HID there is an initialization sequence with a 2nd argument "USBFS_5V_OPERATION"
Please try "USBFS_3V_OPERATION" for the 2nd argument.
Noriaki
I forgot to mention that I already tried changing that argument.
Corné
Hima
That did the trick, thanks!
I thought the VBUS was only used for detection, and since VBUS Monitoring was disabled in the configuration of the USBFS I thought it was redundant.
