PSoC™ 4
Hi
Associated with my other posting about clock behavior, how exactly do you use the ECO clock as an input to a timer?
If I select HFCLK as the existing clock source in a clock (v2_20) that drives a timer, then I get an error saying HFCLK cannot be used.
If I try to use SYSCLK (which is derived from HFCLK) then I get the message that the component requires a clock from the clock block. If I try any of the "routed" clocks I get the same error.
How do I do that? The IMO is not accurate enough for my application.
Ta.
