I compile a piece of code for the CYBLE-222014-00 module (BLE 4.2) and get this info message on the way:
Info: pft.M0077: There is no timing information available for the selected device. Static timing checks will not be applied and digital routing will not be timing-driven. (App=cydsfit)
The code has been used for the CYBLE-222005-00 module before (BLE 4.1) and it compiles without this message coming up. Could anyone tell what this message is? Anything to worry about? Can this be related to I2C not working?
-Tamás
BLE
Welcome in the forum, Tamás!
Are you using the latest Creator version 4.0? When yes, I would suggest you to get in contact with Cypress directly: At top of this page select "Design support -> Create a Support Case" and ask your question. You will be helped by a Cypress engineer.
Bob
Hi Bob, thanks for the quick reply. I use PSoC Creator 3.3 CP3. I guess it means the first step would be to upgrade to 4.0?
At least, give it a try 😉
Bob
