TCPWM in low power mode
I am using two TCPWM to provide two PWM signal outputs to extrernal circuits.
What is the lowest power mode I can enter, while maintaining these two outputs active?  i.e. continue to pulse at their assigned freq and Duty cycle.
It looks like "Sleep" is the lowest I can go.  Can I go lower power than that?
Bob_Marlowe
Level 10
Level 10
No, you cannot. The only exception is when the PWM frequency is very low using deep-sleep and wakeup at the desired moment to switch a pin.
Bob
That's what I thought, thanks Bob!
