vegan_electron
First like received 10 replies posted 10 questions asked
i would kindly ask if it's possible to switch the IDAC's polarity? The configuration in the IDE is fixed? We would control the configuration by software API as needed.
So is this possible?
Thank you and kind regards,
Daniel
Hari
Hi DaRi_1526611
To change the IDAC polarity during run-time, you will have to perform the register writes manually. Attaching a sample project where the IDAC configuration is switched from Sink to source based on a button press.
Hari
Len_CONSULTRON
Level 9
Level 9
Daniel,
It's simple.  There is a Polarity configuration setting.
When you set to Negative polarity make sure the load is connected to allow the current to flow from a voltage source (in the example below: from Vdd).
When you set to Positive polarity make sure the load is connected to allow the current to flow to GND (in the example below: to GND).  In this case, the Voltage source is VDDA.  This may be a limiting factor in your design.
Len
Len
Hari
Hi DaRi_1526611
Hari
Thank you a lot guys! This information helps me a lot.
Thank you very much, stay safe,
Daniel
