Stuck on CyBle_GapClearResolvingList()
DeCo_1926091
Level 4
Level 4
First like received
When I try to clear the resolving list I get apiResult = 2, which I think means CYBLE_ERROR_INVALID_OPERATION.  Apparently, this can be the result if address translation is enabled, advertising is enabled, scanning is enabled or if there is a create connection command outstanding.  I've tried disabling address translation immediately before calling CyBle_GapClearResolvingList() and that didn't help.  I've also disabled advertising before calling it and the result was the same.  I don't think scanning is enabled because this is a remote peripheral server.  And I don't see how a create connection command could be outstanding, but I'm not sure how to test that.
Any suggestions about how to proceed would be greatly appreciated.
Dennis
Yugandhar
500 solutions authored 1000 replies posted 5 likes given
It is recommended to clear the resolving list data when the device is in disconnected state. Please refer to the "BLE_4.2_DataLength_Security_Privacy" code example in the PSoC Creator for your reference.
P Yugandhar.
Yugandhar
P Yugandhar.
