I have a project using a CY8C4024AZI-S403 device. I have running code but wanted to create a simple timer ISR that can perform things like scan for key presses etc.
I've used a GlobalSignal before on a PSoC4 BLE so I added one called GlobalSignal_2 with an attached isr_1. In the configuration window, GlobalSignal_2 uses Watch Dog Timer Interrupt (WDTInt).
I then went into the LFClk setting and enabled the Timer (WDT) as a free running timer (see attachment), added code to main to start the isr - isr_1_start(); -and added code to the isr_1.c file as follows:
CY_ISR(isr_1_Interrupt)
#ifdef isr_1_INTERRUPT_INTERRUPT_CALLBACK
isr_1_Interrupt_InterruptCallback();
#endif /* isr_1_INTERRUPT_INTERRUPT_CALLBACK */
/* Place your Interrupt code here. */
/* `#START isr_1_Interrupt` */
CySysWdtClearInterrupt();
tedsCount++;
/* `#END` */
It compiles and runs but doesn't seem to ever call the ISR as tedscount never increments. If I change the Timer (WDT) to mode Watchdog (w/interrupt) my code seem to get stuck in a doom loop - not sure what's happening
Any ideas what's wrong?
- cy8c4025azi-s403
Please refer to the code example CE210292 for example of how to use WDT in PSoC 4000S for interrupt generation.
Does the WDT clock is enabled by default or you must start it on your main function? did you enabled it?
EDIT:
Just found this blog post about psoc4 and WDT, it might help you. PSoC4 Watch Dog Timer - IoT Expert
