PSoC 4
JaSi_1632926
Contributor
I'd like to set a flag in our bootloader which then should be read by the bootloadable (=application). I can't find anything in the datasheet about this. Is there any standard way of doing it? The metadata doesn't seem to have any custom fields that can be used for things like this.
Thanks, Jacob
EmHo_296241
Contributor II
        Hi Jacob, You can directly write data to a memory location rather than using a variable. If you read the same address in your application, your problem will be solved.
JaSi_1632926
Contributor
Thanks for your answer. I solved it by using SFlash.
Thanks, Jacob
